After 5 days, I returned the Samsung 244T to the store, NFSMW looked/played amazing, seems to be perfect for all other
types of monitor use, except!..FPS, mainly I tested with FEAR but most of the problems I describe apply to Halo
and FarCry also:
Moving forward/back was visually rock solid...
Turning left to right without moving(no direction buttons pressed) was terrible, choppy/blurry/tearing/distorted, V-sync helped,
but wasnt perfect
Turning left/right while moving forward/back...was much better than just turning left/right but not perfect.
Iv tried experimenting with various resolutions/settings using Nvidia's new control panel, the best playable, although text was huge and didnt look as good:
Lowest res available, 480x360
All other settings on full
V-sync on,
Changing the refresh rate didnt seem to do much
It was possible to play at native, and it did 'look' better, but impossible not to finish bottom of the scoreboard, still very hard to see/focus when
panning left/right quickly, not as stable as lower res, Using MouseWare and the game mouse settings it was possible to make the mouse more sensitive, to the point, where it was too sensitive, so Im not sure how a faster mouse would solve this problem,If someone can explain this??
Somehow in firefights the other person always seems to have the edge, and only made a kill if I caught them by surprise..
When I put my old 15" Relisys LCD beside the 244T, I could see when panning left/right that the little Relisys was solid,
and indeed, panning left/right wasnt any different to any other kind of movement, unlike the 244T.
So when I went back to the 15" after 5 days, all of a sudden my score shot back up, I was on a killing spree and in the top
3 in most rounds...I could also make kills while flying through the air..3 kills with 1 clip..close combat was no problem..so much more control!!!
Now...my little U$50 15" Relisys appears to be better than a U$1400 24" Samsung 244T, in terms of playing MPFPS,
Im back to square one, Im even thinking about CRT now!!
Does this problem seem like the popular input lag issue
What is the Maximum size of an LCD display for gaming, before problems start,and are these types of problems only related to LCD/TFT
Which display should I get
and FarCry also:
but wasnt perfect
V-sync on,
