Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > A never solved Activesync problem
Forum Smartphones & PDAs : Windows Mobile - A never solved Activesync problem
Archived from groups: microsoft.public.pocketpc (More info?)
Dear friends:
I am frustrated that Activesync only recognizes COM1 to COM9 as
available serial ports. The problem is that most Bluetooth stacks
generate virtual COM ports in the range of COM10 to COM99, so it makes
almost impossible to synchronize my PocketPC with my notebook using
Bluetooth.
Any hint?
Thanks
Juan I. Cahis
Santiago de Chile (South America)
Note: Please forgive me for my bad English, I am trying to improve it!
Sponsored Links
Juan I. Cahis fumbled, fiddled and fingered:
> Dear friends:
> Bluetooth.
> Any hint?
Have you checked out Activesync 3.8 yet?
Steve Parry BA (Hons) MCP MVP
http://www.gwynfryn.co.uk
Reply to Anonymous
Yes, and it is the same.
>> Dear friends:
>> Bluetooth.
>> Any hint?
Thanks
Juan I. Cahis
Reply to Anonymous
Juan I. Cahis wrote:
> Dear friends:
> Bluetooth.
> Any hint?
I'm not familiar with bluetooth virtual com ports, but are you sure you
can't select lower-numbered virtual ports? I would have thought you should
be able to select any unused com port number. Most usb-serial ports for
example allow that.
Tony
Reply to Anonymous
When you say "only recognizes", are you saying the drop down list in
connection settings? You don't see any other ports available for
connection?
> >> Dear friends:
makes
using
> >> Bluetooth.
> >> Any hint?
> Thanks
> Juan I. Cahis
it!
Reply to johng
In the drop down list only COM ports in the range from 1 to 9 appear.
Any other COM port doesn't appear.
>connection?
>> >> Dear friends:
>makes
>using
>> >> Bluetooth.
>> >> Any hint?
>> Thanks
>> Juan I. Cahis
>it!
Thanks
Juan I. Cahis
Reply to Anonymous
The Microsoft driver for Bluetooth Virtual COM Ports doesn't allow you
to select the COM port number.
>> Dear friends:
>> Bluetooth.
>> Any hint?
>example allow that.
>Tony
Thanks
Juan I. Cahis
Reply to Anonymous
I agree, ActiveSync should list all COM ports available. In the meantime,
check this thread for some information on its first post:
http://www.geekzone.co.nz/forums.a [...] opicId=422
Mauricio Freitas, Microsoft MVP Mobile Devices
http://www.geekmac.com
Bluetooth guides: http://www.geekzone.co.nz/content.asp?contentid=449
Geekzone Software Store: http://www.geekzone.co.nz/store
"Juan I. Cahis" <jiclbch@SINBASURAattglobal.net> wrote in message
news:s8nsu0hm6l7j45gtgvgs4btjvbfudfg27q@4ax.com...
Dear friends:
Bluetooth.
Any hint?
Thanks
Juan I. Cahis
Reply to Anonymous
Dear Mauricio, it worked!!!
After shifting a lot of hidden COM ports, I could give the No. 9 to
Activesync
But God only knows about how many other applications will stop to work
after this big tweaking!!!
It is time now that Activesync should list all COM ports available.
>http://www.geekzone.co.nz/forums.asp?ForumId=8&TopicId=422
Thanks
Juan I. Cahis
Reply to Anonymous
There are 578 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
