I currently have the Evercool WC202 which includes a CPU and GPU block... The thing works great! I am currently running a p4 630 3ghz OC'd to 3.6ghz and the temps never get above 49-50c. Here is a Review for the system.
Also Newegg has it for ~85 after shipping!
I did need to take out the MB to mount the 775 bracket though...
was it...
i haven another question with water cooling and lower temps could turn up voltage and do less harm to cpu with it and i read a review saying that 80mm was pre good
I'm not sure what you are saying - you didn't explain what was in the link or correct it and I don't know what you are referring to when you mention 80mm
