i was using Acronis OS Selector 8.0 to set up a multiple os cause i had heard from someone that it was easy to use and i didnt have sucess with partition magic 8.0 so i decieded to use that i left my computer on for a while and was doing my homework, installation finished and the computer restarted and windows would load properly and i got the blue screen cant remember what it said but i tried to boot in safe mode and it wouldnt let me either still got the same blue screen. So i deciede to pop in the XP disk and when the setup load i hit r and then type in fixboot and i get it to load windows and i uninstalled Acronis OS Selector 8.0 but then i looked at my hard drive my going to my computer and right clicking on my HD and clicking properties i went from 64GB to 209GB used space here are my system specs:
MSI k7n2 Delta2 Platinum
Socket A AMD sempron 3000+ @2.21GHz
768 mb of pc 2700 ram @185
250GB Maxtor Ultra16
PNY GeForce 6600Gt 128mb
Antec Sonata II Case With a SmartPower 2.0 PSU
NEC Dvd/RW
Windows XP PRO
any help would be appreciated
Thanks,
Alex
NEC Dvd/RW
Windows XP PRO
Thanks,
Alex
