problem with Road Challange"
Archived from groups: alt.games.need-for-speed (More info?)
I have for a long time, "Road Challenge".
Since a have, long time ago, another computer, the games wil not working.
I have always the remark "please insert disc".
It IS the legal version, but the illegal version have the same problem. Once
I have changed the drive letter, I have change the cd rom player to, but
nothing helps.
Cd is in drive "L", the games is in stanard map on "M"
My grandson wil play with....so who can help??
Thank,
Hans (from Holland)
3 answers Last reply
More about problem road challange
  1. Archived from groups: alt.games.need-for-speed (More info?)
    "Hans" <hans@DITVERWIJDERENvan-der-ham.net> wrote in message
    news:BbCuc.15294$yh.1919@amsnews02.chello.com...
    Once
    > nothing helps.
    > Thank,
    > Hans (from Holland)
    Are you running any software like Daemon tools or Alcohol 120%? Anything
    like that which creates a virtual CD drive can cause problems.
    If you are, then try disabling all the virtual CD drives and re-installing
    the game.
    Quinda
  2. Archived from groups: alt.games.need-for-speed (More info?)
    working.
    problem. Once
    but
    > nothing helps.
    RC only works with the CD in the FIRST CD drive in the system. If you
    have swapped drive letters, you will probably have to reinstall.
    --KC
  3. Archived from groups: alt.games.need-for-speed (More info?)
    On Mon, 31 May 2004 15:44:14 GMT, "Kasey Chang \(remove EATSPAM to reply\)"
    >working.
    >problem. Once
    >but
    >> nothing helps.
    >--KC
    Never mind, I was going to suggest you to try something, but it won't work.
    You can disregard it now, my original idea was as follows.
    Run Regedit, then go to:
    HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\Need For Speed High Stakes\1.0\
    The key in question is "SrcDrive", which should contain the CD drive letter,
    or in your particular case, "L:\" (mine is "Q:\").
    Of course, since the name varies between "High Stakes" and "Road Challenge"
    depending on what language your installation is in, the actual entry could be
    a little different, maybe something like
    HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\Need For Speed Road Challenge\1.0\
    But I just tried it (changing "Q:\" to "W:\") and it didn't work. Maybe it's
    a good idea to do a full install (if you have enough space) and then apply a
    no-cd crack, that should also protect your original CD from all the wear and
    tear.
    __________ ____---____ Marco Antonio Checa Funcke
    \_________D /-/---_----' Santiago de Surco, Lima, Peru
    _H__/_/ http://machf.tripod.com
    '-_____|(
    remove the "no_me_j." and ".sons.of" parts before replying
Games CD-Rom Video Games
