I'm pretty sure this is a heat related problem, but I'm not 100% sure. I bought a Scythe Infinity heatsink for my AM2 X2 4000+. It's running on a ASUS M2N32-SLI Deluxe mobo. I cleaned off the CPU with 70% isoproyl alcohol (stock heatsink was on it for about 2 months). I think I did a pretty good job. I then used the heat paste that came with the Infinity. I'm not sure how good of a job i did here, I wore rubber gloves and then spread it with a piece of cardboard. I am running the heatsink fanless. For 2 days, it worked great, CPU temps were a little higher (about 4 degrees C), but I wasn't worried since I was using it fanless.
I'm at work and I get a call from my wife saying the computer shut itself down after she was browsing the internet and then left it on to go do something else. All in all, I'd say the computer was on this morning for about 4-5 hours before it shut off. Now it won't even go into Windows all the way before it shuts off, even after being off for probably 30mins to an hour.
This is probably a overheating problem, but what would cause it after running for 2 days with no problems. In those 2 days, I ran Prime95 to stress my temps - the highest it went was 60C. (According to ASUS PC Probe II, the threshold is 90C) Sorry for the long post, but I thought the background info would help.
