Archived from groups: microsoft.public.pocketpc (More info?)
This question has been asked more than once in this group but I still
haven't found an answer.
The problem is that sometimes I find my iPAQ turned on in the morning. All
sync schedules are set to "Manual" except for the Desktop Schedule that is
set to "On connection" so it should not power on for that. And besides, the
only thing set up to synchronize is the clock.
Since I cannot find a pattern for this I guess it has to do with something
that the iPAQ only do once in a while.
Any ideas? The iPAQ Backup schedule is NOT enabled.
i dont know if this helps as i'm new in pockets (i have my ipaq 3630 be
delivered tomorrow ;-) ) but i read in some of polish groups that sometimes
ipaq turnes itself on during night to organise today screen and any
apointments during that day
check if you have battery saving option turned on and see if your ipaq turn
off after certain time of being unused.
If the iPAQ turns on to organize today screen and appointments (the calendar
is empty on my iPAQ though) I can see why it stays on since it's AC powered.
But why doesn't it do that every night then?
/Magnus
"Maciej Ma³aszuk" <p@p.pl> wrote in message
news:csob6m$8pj$1@inews.gazeta.pl...
> sometimes
> turn
> hope it helps
> Mac
My 2210 did this, and I found the cause to be a dodgy USB connection in one
of the ports in my powered four way hub.
I switched to another port (a slave in the back of my separate keyboard),
and all is now well.
If you have a choice of USB ports, worth a try?
"Magnus Persson" <numinel@arsmagica.com> wrote in message
news7O02Ow$EHA.1396@tk2msftngp13.phx.gbl...
calendar
powered.
> /Magnus
> > sometimes
> > turn
> > hope it helps
> > Mac
Reply to message from "Magnus Persson" <numinel@arsmagica.com> (Thu, 20 Jan
2005 08:55:18) about "iPAQ 2210 power on by itself (again)":
I had this on my 3715 but previous advice to disable activesync auto
connect seems to have worked .fingers crossed
Bye
Brett Smith <brettdsmith.mobile@tiscali.co.uk> Thu, 20 Jan 2005 19:22:45 +
0100
=== Posted with Qusnetsoft NewsReader 2.2.0.8
----- Original Message -----
From: "Magnus Persson" <numinel@arsmagica.com> Sent: Thu, 20 Jan 2005 08:
55:18 Subject: iPAQ 2210 power on by itself (again)
besides the other responses you have rec'd, it would be worth noting if
there are any particular apps running on the mornings you find it "awake",
some have reported that having windows media player open (even in the
background) can prevent the devise from powering off after the preset period
of time. other apps may be interfering as well. the next time you find it
powered on in the morning go into the running apps module and note was is
running, and then see if you can see a pattern.
newsDXxlVs$EHA.3424@TK2MSFTNGP11.phx.gbl...
the
| /Magnus
I have already tried two of the six ports on the motherboard and currently
have it connected to a USB hub. But I had another computer a month ago and
it did the same there (no USB hub on that one). So it must be something
else.
/Magnus
"Voyager" <dummy@dummy.com> wrote in message
news:ejvpJhw$EHA.3592@TK2MSFTNGP09.phx.gbl...
> one
> calendar
> powered.
>> /Magnus
>> > sometimes
>> > turn
>> > hope it helps
>> > Mac
The only app beside the default ones are Spb Pocket Plus.
Well....guess I have to ignore that fact that my iPAQ is on in the morning
once in a while.
"KDE" <knott_me@NOSPAM.hotmail.com> wrote in message
news:eqhkkHz$EHA.2984@TK2MSFTNGP09.phx.gbl...
> period
> All
> is
> the
> something
> | /Magnus
> /Magnus
Download and install PHM Tools, they allow you to view the task list and
see anything scheduled to go off. You can manually delete them, but
better still it tells you the app that will be run, so you can disable
it properly.
>once in a while.
What do you use to close programs on your iPAQ? I'm sure that you know that
the red X only sends a program to the background, but leaves it running. If
once in a while you didn't use a task switcher to actually close a program,
but used the red X to background it and forgot to close it later, then after
the wake up at midnight to sort alarms some programs would continue running,
preventing the iPAQ from turning off. This would match the symptoms that
you have reported.
A great many people think they are thinking when they are
merely rearranging their prejudices. - William James
Steph Peters delete invalid from incm@sandbenders.demon.co.uk.invalid
Tatting, lace & stitching page <http://www.sandbenders.demon.co.uk/index.htm>
One of the features of Spb Pocket Plus is to close the programs instead of
minimizing them when tapping the X.
Guess I'll never solve this...
"Steph Peters" <xda@sandbenders.demon.co.uk.delete.invalid> wrote in message
news:2i67v0d7qh8g4s8964h40qepuuuoefl9hr@4ax.com...
>>once in a while.
> that
> If
> program,
> after
> running,
> you have reported.
