Hi, you will probably hate me for posting another topic about the pentium 805d. I read the guide on overclocking it but im really stuck.
I have a asrock conroe xfire-esata2 mobo, and 2gb gskill 677mhz,
Ok, my bios is obviously diffent from the bios they used in the guide, but i thought i was getting the idea. (before i continue, i need to make clear that this is my first own built pc, and i am a complete noob not knowing all termanology)
I put the latencies to 4-4-4-8 just like it says in the guide, but they could get higher ram freqs. mine will only go up to 533. And increasing the freq of the cpu just makes the system not reboot, still on, fans ect, no responce from power switch or reset and monitor goes idle. I turn the psu off and on, and it tells me that the setting didnt work and it has put them to default.
I dont know what i have to do, and i feel as if i dived into a very deep pool, but i am a learner and i have to learn somewhere. SO if any of you could help me out, i would really appreciate it.
And what confuses me, is that the memory is dual chanel but on the boot up screen it says single channel memory. ? I am really confused
