whenever i try to watch or stream any type of video on my computer, the media program will jump to 100% cpu usage and my system will bogg horribly. i have to open task manager and do my best to close it down (which takes forever) or just restart my computer. i'd like to avoid reformating. my friend bought the same mobo at the same time as me and his works fine. my specs are:
i tried using wmp 11 beta when i firsted got my system built and it acted weird so i was like "i;'m just going to have to use a different program" but it did the same thing with wmp 10, some crappy video viewer, and another program that someone said worked when they had this problem but that didn't.
i'm using the mobo driver my motherboard came with, and i tried using the newest nvidia driver but that didn't work so i switched over to the one that the disc had.
could it be a hardware problem, or is it most likely just some driver screw-up?
