Yes No
Ads
Tom's Hardware > Forum > Networking > Routers & Gateways > Acer Aspire 3000 and Belkin wireless router connection issue
Forum Networking : Routers & Gateways Acer Aspire 3000 and Belkin wireless router connection issue
I have a belkin wireless router which my HP laptop has no problem connecting to and allowing me to browse the internet. My Acer Aspire, however, will connect and allow me access to the internet but then after about 15 or so minutes will still say I am connected but I cannot open any pages. Repairing the connection does not work. I have to reset the router and restart the computer to re-estblish a connection that works. Any advice?
Reply to russman
Are you picking up a valid IP address that the router is handing out?
Have you checked your cabling to make sure it's not damaged and has a good connection?
Reply to riser
- 0 +
Quote :
yes. It doesn't even show a connection was lost. It just refuses to allow me to access the internet. It will work for a while, then poof. "Unable to connect to server." The only way to re-establish is to unplug the router and restart the Acer. No problem with my HP laptop, the connection is still available and I can access web pages.
After I reconnect, I disable "use windows to configure my wireless network settings" and the connection lasts much longer. In fact it hasn't dropped once today. I wonder if that was the fix? It seems odd though.
Reply to russman
- 0 +
windows wireless zero configuration has it's share of problems.. I would always use the software that came with the wireless over the Windows version.
Reply to riser
- 0 +
I have heard that too. The laptop is an out of the box and has a broadband network adapter. There is no software that came with it.
Reply to russman
- 0 +
Check the wireless card vendor's website for their software to establish a connection..
Reply to riser
A friend of mine has the same problem with her Aspire 3000. Sometime the connection stays good for a few hours, but more often it becomes very unreliable after a few minutes. Windows XP doesn't seem to think there is a problem.
The problem exists with both the wireless and the LAN connections.
Did you find a solution?
Reply to naughtybeagle
There are 2072 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
My desktops internet. HELP
By Realbeast, 1 day ago:
Sure could be a virus or malware, you should use a good free antivirus and...
Best offers
Top experts
