Tom's Hardware > Forum > CPU & Components > CPUs > plz help..my pc switches off(like a crash) without motive :|
Forum CPU & Components : CPUs - plz help..my pc switches off(like a crash) without motive :|
i dont know what causes this, but i think it could be the voltages. on the regullar voltages 3.3, 5 and 12, i have the following values: 3, 4.9 and 13 volts. could this be the problem ? However my cpu temp never raises above 50 degrees, so that is out of question. I dont think it might be the HDD, RAM or graphic card either, this would result in freezing the system, not pwr it off (by the way, i've disabled the overclock on cpu&gpu)
Sponsored Links
i guess i have a match of one point: it switches off when i play 3d games like counter-strike.
it is simply powers off, not like a shutdown but like someone unplugged my power cable, and then i cant power it on untill i have unplugged the cable and plugge it again. And becouse of this, a power failure is out of question, as i have the "power on" feature activated after an unexpected power loss.
Reply to dawgkiller
ANS model L-C B350 at 350 watts...
Reply to dawgkiller
hm...i not think this should be the problem...now i have only one hdd (maxtor 80 GB) , one cd-rw, and one floppy. my cpu and gpu are both running at default speed. As i had 2 HDD's before, the cpu and gpu overclocked, i've never encountered this problem...so ...i'm a little confused, the 350 watts is more than my piece of crap can suck, in my pov.
Reply to dawgkiller
so, it might happened to damage my cpu due to oc ?
it has been running at 2.36 GHz (2.08 default) with 400 fsb instead of 333 for an year i think. the voltage is 1.75 (1.65 default).
i rather suspect my psu or my mobo, as both are some nice pieces of junk.
by the way, i cant lower "a little" the voltage, it has only 2 values possible (1.65 or 1.75), and at 1.65 my cpu is not stable however, since i bought it. (the 1.75 voltage solved the problem at that time)
Reply to dawgkiller
I had a problem similar to this, basically, at random my computer would just freeze, I didn't have to be playing a game for this to happen though. The only way to start my box again would be to flash the power, the reset button didn't do anything. Also, when I tried to hibernate my box it would save everything and as soon as it shut down, it would immediatly start up again. What ended up being the problem for me was my video card. I have an AIW x800xt and it's got the additional power plug on it. If I left that unplugged, my system ran rock solid again except when playing demanding games, which then my display would occasionally corrupt which I'm guessing was due to the card not getting enough power. But the problem was the power electronics on the graphics card itself, don't know if this is your problem, but hopefully it's a help.
Reply to cyprod
Quote :
i truly doubt my fx5200 @ 64 bit could cause such kind of problem :wink:
however, 10x4 bothering to try to help me.
Reply to dawgkiller
This has happened to me before. I once put my room heater too close to my PC and it just shut down. The only way to start it again was to switch off power from the wall socket and turn it on again. This kept happening for 5-10 mins before i realised my stupid mistake. Once I turned my heater off and waited for five minutes it was fine.
Basically ur PSU is overheating. PSUs are ment to shutdown when they overheat. Get a new PSU, may be with higher power.
Reply to 0zzy
i think i'm going to disasemble my PSU and clean it out of dust :)
Reply to dawgkiller
WOAH! new ps time boy. most powersupplies will operate within 5% of the stated voltages. your 12v is way high and your 3v is too low. yes 350 is heaps for that config but if you have a cheap generic thing then your likely to run into trouble. remember that about 25-40% of the stated power rating is lost to heat.
Reply to mainyard
huh...10x for helping guys...i found the problem...you wont believe it, it wasnt my PSU nor my cpu either...it was the mouse. lol, yes. a short-circuit within its cable was causing the trouble, i've fixed it and all is now back to normal. so, the rabbit jumps from where u expect it less...
by the way, i appologize if my english sux, i'm from romania :)
Reply to dawgkiller
Quote :
Those damn rodents get you every time....
Reply to Gneisenau
There are 1031 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
