Tom's Hardware > Forum > Games General > Games General Discussions > ATI Radeon 9700 PRO and Need For Speed Underground
Archived from groups: alt.comp.periphs.videocards.ati,alt.games.need-for-speed (More info?)
Hey all,
I am running a WinXP, 2.4g box with a gig of ram and a 9700PRO.
Whenever I play NFSU 1 or 2, the card will cause a crash after about
20/30 mins. I can play UT2004 for hours with no hiccups, but NFSU
crashes me. I know it is a video card crash because I get the lines
all over the screen. Any ideas on what could be causing this?
Thanks.
Sponsored Links
rsc wrote:
> Hey all,
> Thanks.
What drivers you using ?
The Catalyst 4.10 work fine....
Also check your card is not getting too hot.
My original fan on the Card burnt out a few months back....put a new
cpu-type fan on it...
and Bingo...works fine....
all maxed-out on NFS Underground....
Jez
'Realism is seductive because once you have accepted the reasonable
notion that you should base your actions on reality, you are too often
led to accept, without much questioning, someone else's version of what
that reality is. It is a crucial act of independent thinking to be
skeptical of someone else's description of reality.'-
Howard Zinn
Skype callto://hellward
NFS Porsche Unleashed, Hot Pursuit 2, Underground.
Yeowww
Reply to Jez
I am using Catalyst 4.10. I opened the box and noticed that the fan
on my video card is not running. Does the fan on an ATI 9700PRO run
all the time? I think the card is overheating. Is installing a new
fan easy?
Jez <iced_spear@NOSPAMdsl.pipex.com> wrote in message news:<Ufudnba9HIihxwjcRVnygw@pipex.net>...
> rsc wrote:
> > Hey all,
> > Thanks.
> Jez
> Howard Zinn
> Yeowww
Reply to Anonymous
> all the time?
Yes, it's supposed to.
> fan easy?
Quite easy...but you have to be very careful.
I haven't been able to find an exact replacement for the original...even
after a few days looking through the model numbers, but a CPU fan did
the job, although you have to find screws that are a bit longer...
then screw it straight onto the heat sink...
Hopefully someone here could give you better instructions..
Meanwhile, I'd say don't run the card...it'll burn out.
>>rsc wrote:
>>>Hey all,
>>>Thanks.
>>Jez
>>Howard Zinn
>>Yeowww
Jez
Howard Zinn
Yeowww
Reply to Jez
There are 696 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
