As expected, Intel’s finally pulled the covers off of two new Atom chips. Read more
The two upcoming new members to the Intel Atom family will be held back from release by a couple of weeks. Read more
Tired of seeing the same old 1.6 GHz version of the Intel Atom? According to an internet report, soon there will be more numbers to pick from. Read more
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
Eager to let you know it’s been busy, AMD is launching four new processors today: the first Athlon II, a dual-core Phenom II, and two low-power 65W Phenom IIs. We bought ourselves a new Pentium E6300 and let loose with AMD’s latest. Read more
