I finished my first build a couple of weeks ago. The build consisted of:
GIGABYTE GA-965P-S3 Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard
Intel Core 2 Duo E6300 Conroe 1.86GHz LGA 775 Processor Model BX80557E6300
2x Seagate Barracuda 7200.10 (Perpendicular Recording) ST3320620A 320GB 7200 RPM IDE Ultra ATA100 Hard Drive
Anyways, the build was fine. I was only using one dvd drive and one hard drive. I had two others I wanted to put into the system, but being a first timer I completely missed the fact that the motherboard only had one IDE port on the motherboard. Well, I decided just to order a pci ide card, (HD CONTROLLER SYBA|SD-ATA133I PCI R - Retail to be exact. Here is where the fun comes in.
I installed it, turned on the computer, xp recognized it. It installed. Turned off the system, plugged in the two hard drives (one seagate, and one western digital I had from my other computer), but then the computer wouldn't boot. It would hang at the boot from cd/dvd command. So I unplugged it from the seagate and it would boot into windows, but it wouldn't recognize the disk.
Long story short I tried a whole bunch of combinations, played with the bios, etc. I got fed up and bought usb enclosures for both disks. Neither of them worked on the new build. Tried plugging them into a laptop. No luck there either.
So any support? Do you think the hdd's are dead? I find it weird that the one that was working fine doesn't work anymore. Any input would be greatly appreciated! Thanks!
