Hi,
I bought a new computer the other day but now I have some problems. First off, here's the comp:
Cooler Master Mystique 631, Black Aluminium, Window (without PSU)
Hiper Power Supply ATX 530W Black, 120mm Fan, 4xSATA, 2XPCI-E, 20/24pin
AMD Athlon 64 X2 4600+ 2.4GHz Socket AM2 1MB, BOXED w/Fan
Corsair Value S. PC5300 DDR2 2048MB Kit w/two matched Value Select 1024MB
MSI K9N Platinum, nForce 570 Ultra, DDR2 ,Socket-AM2,2xGbLAN,Firew, ATX, PCI-Ex16
PowerColor Radeon X1900XT 256MB GDDR3, PCI-Express, ViVo, Dual-DVI-I, Retail
Sony DVD-burner DWQ120AB2 IDE OEM Black DVD±R/RW (Dual Layer)
Samsung SpinPoint P120S 250GB SATA2 8MB 7200RPM
Ok, so this was my first time building from scratch and it took some time but when i finally finished I wanted to try it out to see that everything worked. It tried it without monitor the first time and every fan and so on was spinning and nothing seemed wrong. Then i tried to open the cd-rom but it wouldnt open and the light in the front was constantly on. So finally I figured that when I unplugged the IDE cable the cd-rom worked just fine to open and close and the light was just on the moment i opened or closed.
Then i tried to start up with a monitor but i didnt get any picture, just the "no signal" message. I've tried to unplugg the cd-rom completely out of the system and tried to reset CMOS. And I've made sure the card isn't loose or anything and I also tried the other slot on the MB and I've tried both connectors on the back with two brand new adaptors since the 1900xt comes with other connectors. I'm not sure about cables and stuff like that but I've got a, I think it's 6-pinned, cable attached to the graphic card. Oh, and by the way, the fan on the graphic card is spinning as well so it seems it's got power.
So I'm not the most experienced guy and i hope I can find some guidance here and I would very much appreciate any help concerning the graphic card, cd-rom or both.
