Hi all,
I am using the Asus P5W DH Deluxe motherboard. I have my WD Raptor 150GB HD running fine as SATA, but I am trying to get my IDE HD's hooked up.
I am connecting the HD's to the black JMicron IDE connector. (I tried using them on the blue, then neither the HD or my DVD burners worked.)
I am trying to use a Maxtor DiamondMax Plus 9 120GB ATA 133 HDD. I have tried setting the jumpers as master, slave, and cable select, and tried using both positions on the IDE cable (tried other IDE cables). I know the HDD works because I can put it back in my other computer, and it works fine there.
I can look in the BIOS and it recognized the HDD there if I look at boot devices, and hard drives. However on the main page that shows primary and slave devices it does not appear. (Only showing my one SATA HD?? and my two IDE optical drives.)
When I go into My Computer in Windows, I see the drive, however it doesn't show a total space or free space category. If I try to open the drive, it pops up a message about the drive not being formatted, and asks me if I want to format. I try to format (using either the long, where it runs for hours and then messes up, or the quick) and it will pop up with; "Logical Disk Manager: The format did not complete succesfully."
If I look in Device Manager, I see MAXTOR 6 L080L 4 SCSI Disk Drive which seems wrong because I didn't think it was SCSI.
If I look in the Computer Management program in Disk Management I see the correct capacity, free space, and the status says Healthy (Active), however I can not format the drive there.
I have tried calling the ASUS technical support, but I wait on hold for 5-10 minutes, then somebody answers asking to take my number and saying they would call me back. I have called 3 times in the last week, and they have yet to call me back. I told one of the people this and asked to wait on the line, and I stayed on the line for over an hour with no answer. So it doesn't appear they offer any kind of technical support.
Does anybody have any ideas on what the problem might be? I know the manual says the JMicron IDE connector won't work with ATAPI drives, but I don't think that is what I have.
I also notice a weird JMicron Raid Configurer program that is starting in the taskbar with my computer, but it doesn't show any information. I don't want to use these HD's as a RAID, just regular ones.
Thanks for any help.
