What do you mean, they cant see each other? Cant ping the others? If so, then make sure u installed tcp/ip correctly on windows machines (on linux, most of the cases it should work with default install), assigned ip adresses to machines and put them in the same network. If they can ping each other, then you are finished, ready to install the aplications (or set up windows sharing/smb).
