PROBLEM: No signal on monitor when I boot up?????????
Last response: in Systems
This is a brand new build just got parts delivered two days ago. I've got it all put together, but when I boot up the monitor ends up with a no signal on it then goes into sleep mode. Tried connections, taken out gpu, I can only use dvi connector because the gpu doesn't have vga. I'm sure others have had this problem, I just need a little direction on what steps people normally take, I appreciate any suggestions.
Asus p5n32-sli se deluxe
C2D E6600
Xfx 7950 GX2
2GBs corsair ddr2 800
Viewsonic vx922 dvi cable only.
This might be an obvious question MN, but....take a look at the back of your graphics card. For instance, I have 2 BFG 7900GT OC's and EACH card has 2 DVI inputs on the back. Now if you look at the card, there may be a number beside each dvi input. ..# 1 and # 2....these are for hooking up AND running 2 monitors at the same time.
If you have your monitor hooked up to input #2, that may be why it is not "seeing" your monitor. Think of it as input #1 being the "master" input and #2 is for the second monitor.What if ther are no numbers on the back of the card? Well gemerally, if you are looking at the back of your case with the card installed, the MASTER input should be the one on the LEFT.
I hope this helps if you haven't tried it already.
One other trouble shooting tip would be to get the monitor drivers DIRECTLY from Viewsonic's website and install them as well.
Hook up a standard crt monitor with a crt adapter and try that to see if it's not your dvi connector.
Antec P180 Performance Case
SeaSonic S12 600w PSU
Asus A8N32 SLI S-939 (bios 1103 V02.58 )
RealTek 97 Onboard
ATHLON 64 X2 4800+ Toledo Core (AMD v 1.3.1.0/MS hotfix/ Dual Opt)
2 G's of Corsair 3500LL Pro @ 400Mhz 2-3-2-6-1T
2- BFG 7900 GT OC in SLI (NV 91.31)
WD RAPTOR 74.3 G's / XP Home / SP2 & Apps
Maxtor SATA II 250 G's /Gaming / Movies / MP3's
Maxtor SATA II 250 G's /backup (unplugged)
Sony CDrom 52X
Plextor 708-A DVD/CD rom
Razer DiamondBack Optical mouse
Logitech Z-5500 Dolby Digital 5.1 THX 500w
MOBO: Asus p5n32-sli se deluxe
CPU: E6600
Ram: Corsair xms2 ddr 800
GPU: XFX 7950 GX2
PSU: PC P&C 610 watt
Monitor: Viewsonic vx922 19" 2ms
SC: X-fi Platinum
HD1: WD Raptor 74gbs
HD2: WD Caviar 250gbs
Optical: Samsung 48x dvd/rw
Floppy: Samsung
I havn't even installed the OS yet, the monitor reads "no signal" on boot. I booted it about three times and it has reached the beginning of the bios ****, but then sputters and freezes. Then about twenty more boots I get nothing but "no signal" on monitor.
Does this Mobo support ddr-800, my buddy read the manual it said it's highest 667mhz and 533mhz. The monitor has dvi and vga connections but, the GPU only has dvi connections?
Try "bench-testing" your setup by taking it out of the case and running the MB w/only RAM and video card. If your MB uses an SLI bridge card to set SLI mode vs normal mode, make sure it is properly mounted.
Ask the community
