Tom's Hardware > Forum > Overclocking > General Discussions > PROBLEM: No signal from monitor when I boot up computer
Forum Overclocking : General Discussions - PROBLEM: No signal from monitor when I boot up computer
This is a brand new build just got parts delivered two days ago. I've got it all put together, but when I boot up the monitor ends up with a no signal on it then goes into sleep mode. Tried connections, taken out gpu, I can only use dvi connector because the gpu doesn't have vga. I'm sure others have had this problem, I just need a little direction on what steps people normally take, I appreciate any suggestions.
Asus p5n32-sli se deluxe
C2D E6600
Xfx 7950 GX2
2GBs corsair ddr2 800
Viewsonic vx922 dvi cable only.
Sponsored Links
Wow, where to start..... Depends on if you have all the proper cables connected. Power supply to video card, motherboard, etc. Cards seated properly? More info...
Reply to tcsdoc
- 0 +
I had the same problem two weeks ago with a Core 2 Duo 6600 CPU and an Intel mobo. Because this was the second machine I had built, I swapped out every component with no results. Then I called Intel tech support. They knew immediately what the problem was. I had ordered the right KIND of RAM but was too new at building my own computer to check the RAM's specs for its voltage rating. The RAM was rated at 2.2 volts and the motherboard specified 1.8 volts. The right kind of RAM solved the problem, although I had to do a BIOS recovery procedure once I had the right RAM.
Reply to CJBLT
Quote :
when i dont fully set RAM in it's slot it keeps the computer from working. If all cards are in properly, then maybe it's the RAM like CJBLT suggested.
Reply to aequalsb
There are 411 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
