Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Irritating Graphics Card Problem
Forum Graphic & Displays : Graphics Cards - Irritating Graphics Card Problem
I have a particularly infuriating problem with my graphics card. During gameplay (Half Life 2, Splinter Cell Pandora Tomorrow, Silent Storm and even google earth!) my machine locks up temporarily (usually for about 15 secs) and the sound becomes corrupted. Sometimes it even happens consecutively.
I have a Geforce 7600GT OC from bfgtech. Their support people initially told me the problem was related to an insufficient power supply. I have since upgraded the system to a 600W unit which has two 12v rails, each supplying 19A. The problem has persisted. Any thoughts?
The rest of my system is as follows:
AMD Athlon 64 3200+
Gigabyte GA-K8NF-9 Socket 939 Motherboard
Seagate Barracuda 7200rpm, SATA 150 120Gb Harddrive
DVD Drive
1GB (2x 512mb Corasir PC3200) RAM
USB driven wirelss dongle and mouse.
Two case fans.
Sponsored Links
Do you have a sound card?
Sometimes when I played half-life 2, the sound and graphics locked up. Very annoying. I read on creative forums and steam forums that it could be a problem with soundcard drivers. I have a creative x-fi xtreme music.
Reply to Thorax
- 0 +
Try using just 512 ram and see if problems persist.
Reply to Cracu
- 0 +
I don't have a soundcard, I am currently using the motherboard on board sound. I was planning on upgrading at a later stage.
I will try removing one of my RAM chips and see what happens.
Reply to afro
- 0 +
I tried removing one RAM chip and the problem has continued.
Any other ideas?
Reply to afro
- 0 +
hmmm... maybe disable sound on bios and run your applications without sound.
This is a new PC? or you just upgraded your video card recently?
when u saw this problems for the first time? (windows reinstall? drivers update? component update? from nowhere?)
Reply to Cracu
- 0 +
Sorry, yeah this a new PC I built myself. I have not had any problesms like this myself. I have been having this problem since I first started using it.
Would the addition of a soundcard potentially resolve the issue? I think I might have a old one knocking around somewhere.
Reply to afro
- 0 +
load bios default.
disable the sound card (from bios). Run those applications again and see what's happend. Run 3dmark'05 or '06 too if u have it.
Also... be sure to have latest drivers for both motherboard and videocard.
DirectX too.
Reply to Cracu
Quote :
Any other ideas?
Did you try both RAM chips on their own? It may (is unlikely admittedly) be a faulty ram chip. Can you run memtest (google it!) and see what it show you?
Reply to 13thmonkey
- 0 +
Ok,
I have tried alternating the RAM chips and the problem has continued. I have now put them both back in.
I have purchased a sound card (Sound Blaster Audigy) and installed it. I have removed the previous motherboard sound drivers and disabled the onboard sound in the BIOS.
The lockups are still happening but the corrupted sound doesn't happen anymore.
I am running memtest while I go out for dinner!
Reply to afro
most likely not the problem but what psu do you have.
also have you defragged your hard drive and done a disk check. it could be that it is having to access the hard drive often.
Reply to strangestranger
- 0 +
I have a Jeantech 'Arctic' 600w power supply JN120F-600 (only two days old).
I will try the HD things.
Reply to afro
hmm, that might be your problem. maybe not but jean tech i think are the lowest of the low. thats the sort of thing you find sold in pc world over here in the uk.
if i am thinking of the same company those are the psu's sold with cases which should be avoided at all times.
is your cpu or graphics card overclocked?
Reply to liquidpaper007
- 0 +
My CPU is not overclocked. My graphics card is sold as 'overclocked' if that makes any sense. I have not done anything to it myself. See
http://www.bfgtech.com/7600GT_256_PCIX.html
for the details.
I am in the UK too and I did admittedly buy the PSU from PC world after a bout of frustration with the two others that I tried. Would this really be the difference? Any suggestions be looking to get instead?
Reply to afro
- 0 +
Get a Hiper PSU , very good quality PSU for the money
http://www.aria.co.uk/ProductInfoComm.asp?ID=24512
Reply to d1ck0
it shouldn't be but you never know. pcworld are just pathetic and should i think be shut down for fraudulent advertising about their products capabilites. no joke.
still it should be good enough but i wouldn't rule it out.
try your grfx card on a mates PC and for that matter try a different grfx card. also ensure that all your drivers are up to date. i'd say that BFG are yanking your chain and it is a grfx card issue
Reply to burn-e86
- 0 +
BFG finally came back to me (after a number of emails regarding my uprated PSU) and said that the problem might be related to the IRQ assignment of my graphics card.
My Graphics card is currently assigned to IRQ PCI 18 as is a ' Texas instruments OHCI compliant IEEE 1394 Host controller'. Could this be causing a conflict and the problem?
Reply to afro
- 0 +
just a thought - would temporatily "underclocking" the graphics card be a worthwhile experiment, just in case the card was clocked too-optimistically? This is easy enough to try with Nvidia control panel (and appropriate patch to enable clocking changes).....
Reply to mdmoy
- 0 +
yeah give underclocking a go, my gainward 6800GT is meant to be able to run 400mhz stable but it locks up after an hour or two of gaming and i have to reset.
what are the temps of the room your pc is in? the overclock on your gfx card maybe stable in the airconditioned test labs back at BFG but your room might be a different story. :roll:
Reply to locky28
i'm by no means an expert so...when i say
what tha f*** is an IRQ?!?
IEEE 1394 is also known as firewire. which accordingly means that either you have the wrong info, or your grfx card is considered a firewire controller similar to a USB host controller.
i *think* that your mobo has an onboard firewire controller though i cant be bothered to find out...
on the underclocking thing, your card is suppose to use better components, the hand picked ones that are more durable then standard 7600s with better cooling as it uses a non standard heatsink.
Reply to burn-e86
- 0 +
I have tried disabling the 1394 controller from the BIOS which did not solve the problem.
How do I go about underclocking my GPU?
Reply to afro
If you are not using any firewire devices then you may as well disable it in BIOS, by the way what graphic drivers are you using I have found the 84.21 seem to work best for me, Oh and stop having a dig at PC World, their incompetence and over charging is keeping me in business. :lol:
Reply to mousemonkey
That it maybe but this one is cheaper and has given me no problems whatsoever http://www.aria.co.uk/productinfocomm.asp?id=19862
8)
Quote :
to underclock ur Gpu have a look at this tutoral
http://articles.networktechs.com/39-p1.php
of course you might want to get more info first and of course its at your own risk etc. etc.
just because it says overclock doesnt mean u cant underclock just thought i'd mention that.
but since it's so unstable, and messing around with the Nvidia BIOS might viod the worrenty, id mention this to them ask them if it will.
and also furter risk is that since your card seems to be really unstable, there is a chance that it might brick it when you are changing settings...
Reply to burn-e86
Quote :
IIRC an IRQ is an interrupt request. a device uses this to send a signal to the cpu saying it needs its attention. if 2 devices share an irq then it can cause conflicts as the cpu is receiving 2 different requests from the same IRQ which obviously cannot be handled at the same time. afaik that is what it is.
the firewire is only a communication port and will communicate through the mobo using the pci-e bus which is also used by the gfx card so maybe that is why. i ain't too sure though although assigning another IRQ might help.
Is there a yellow question mark when you goto the Devices listing in Hardware tab? Usually if there is an IRQ problem you'll see that question mark there and it does need to be fixed.
Reply to wolfman140
- 0 +
I suggest trying to run one of your games that locks up in a reduced window and run the task managerat the same time, if you can see what process is hogging your resources enough to cause you system to stall then you should be able to track down the problem driver or hardware.
Or you can start underclocking or removing things or buying new hardware....or using your fancy new CPU as a lawn dart.
Reply to blunc
There are 1239 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
