Hi
I just put a AMD64 3500+ into my machine (upgrade from a 3000+ and I have been having some problems ever since
My system will randomly reboot, and when windows comes back to life I get a message saying 'Windows has just recovered from a serious error' or somthing along those lines (I will edit this post and let you know exactly what it says next time it happens), this occurs fairly often. Ive run Memtest86 for about 12 hours with no errors, but when I run Prime95 I get an error almost right away (always along the lines of FATAL ERROR: Resulting sum was X, expected Y, hardware failure detected consult stress.txt file) So im pretty sure its a problem with the CPU.. ( I got the CPU from a friend for free, so I cant return it to the store for a new one , so if it is, Ill have to put my 3000+ back in) anyways My question is, does anyone know of any other test programs I can use to be sure before I ship this lovely little processor back to god knows where for replacement?
Here are my system specs
ABit AV8
2x512 KVR ram 400mhz
Radeon 9600 pro 256m
Windows XP pro SP2 (I just reinstalled)
350W Enermax PSU
anyways if anyone has any test programs to suggest let me know, or any suggestions of other components to check before I assume it is the processor thats causing the problem
Any help is apreciated
-spakman
ABit AV8
350W Enermax PSU
-spakman
