Im wondering if anyone has had any luck at all with the 64bit Vista RC1 build running single or dual GeForce Go 7900GTX's. I cant get any drivers to take. When they do load, either i get a blue screen in sli mode, or when i disable one i get that it didn't work and vista disabled it and loaded the standard vga driver for it. Code 43 error actually.
Nvidia doesn't have ANY beta drivers for the go series of cards, and laptopvideo2go.com has some 3rd party ones, but i cant get them to take.
Any recommendations or fixes would be MUCH appreciated. I really want to try out this Aero interface.
