Hi, I am building a new PC with:
Asus SLI mobo
dual AMD2 4800+
only one Nvidia 7950 gx2 (for now)
4 sata HD (2 7200, 2 1000rpm)
DVD rom
The PSU should be no trouble - I'm getting a 750W Tt
Problem is ... no matter what I calculate, I am sure that the power draw will be more than the 15A that the mains AC socket can supply.
I may be able to get a 20A circuit put in but regulations seem to prohibit higher than that in the home.
I can't see how other ppl use such systems (and bigger ones) on home AC power!
So, will I have trouble when I finish building the system from the point I plug into a 15A (or 20A) AC socket and turn it on?
Yes I have read the FAQs and calculators but seen nothing that tells me how ppl normally deal with this type of issue.
Yeah thanks everyone, I was not multiplying the rated amperage by the ratio of 12V/wall socket voltage.
e.g. the rating is 48A and at 85% efficiency that is 56A. So if I assume most of the power is taken on the 12V rails then draw on the wall socket is
56 * 12/120 = 5.6A
