Hi all, Just built myself a new pc, and found the easiest way to get data from my old pc to new, was to use my IDE port and connect my IDE disk drive from my old pc, then just copy data files across. In order to make things clearer for myself I renamed the old drive "old drive" rather than continue to use the name it had when it appeared on my new pc under the explorer tree, [I dont remember what it was called before hand - it may just have been labelled "local drive"] the drive letter was h: this remained unchanged.
Ok so now i want to put my "old drive" into my old computor, and my old computor wont boot up! it doesnt recognise the "old drive" even though this is the original drive for the old computor, im guessing that my renaming it from "local drive" h: to "old drive" h: must have somehow changed something in its settings.
How can i get this drive to work again in my old pc, without formatting it and re-installing - as i still have some data i want to get hold of, like email addresses from MS Office outlook 2003, etc. - and i cant access them when its installed in my new pc. Also this old disk has programmes on that are downloads that i have paid for and dont want to loose access to [via the old pc that is].
Would really appreciate your help.
Cheers
Ade.
Cheers
Ade.
