I am wanting to set up a DIY kit. I have read very much about it but would like some expert opinions when making my final decision.
I plan on using a Danger Den MAG II pump.
I am going to use Swiftech Apogee water block, and don't plan on cooling GPU right now.
I want to use 1/2" tubing (if that makes the most sense, let me know.)
Here is where I need help. I really want to have a totally internal kit, I move my PC a lot and it seems less dangerous and more accomodating to keep it internal.
Thus said, I plan on using a single 120mm radiator on my D805.
Does dual-pass vs. single-pass make a large difference in amount of heat dissapated? I have been looking at either Black Ice Pro or Black Ice Xtreme.
Is the advantages of dual-pass worth the extra $15 or so? I know it's not much, but if it isn't going to gain me anything to go for the Xtreme I can just as well keep it.
Can anyone recommend a good reservior (any bay or standalone is fine) for cheap (preferably from the website linked above, they seem to be cheap). And link to me from the website the clamps and hose I should get? I want to use UV red dye and I am just going to use distilled water I think.
Any suggestions other than the requested are very welcome! Keep in mind I am trying to make a budget kit, but with better performance than complete kits (ex: Bigwater SE, Gigabyte 3d Galaxy)
