Tom's Hardware Forums » CPU & Components » CPUs » I need some help. PC wont turn on.
Add a reply
 Word :   Username :
 Page :   1  2
Previous
Author
 Thread : I need some help. PC wont turn on.
Profile: addict
More Information
Ok here is the deal.
I have a 2 year old dell, wanted to see what socket the cpu was b/c I was wanting to upgrade it. I unpluged all power connectors, took PSU out, took heatsink off, and got the number. Put the heatsink back on, PSU back in, plugged the power connectors, mobo, CD, and HDD, back into place. Once I had eveything hooked back up, I plugged all the cords to the back, mon,mouse,keyboard,etc. Set the case back up, press the on button, but nothing happended.
The lights on the back are working, so is the light on the Mobo.
What do I need to do to find out why it wont turn back on? Any thoughts?
I am not an expert, but do know a good bit about this stuff.
Related Pr oduct
Profile: Eternal Poster
More Information
You prolly would have got that info you needed from CPU-Z program.
I'd re-go through everything you un-installed. Re-seat the RAM, video cards and such.
Also, you will should reapply thermal grease, since you took off the HSF.
Profile: addict
More Information
Couldn't find the program to locate socket number. I didnt take out the ram, and the video is built in. What kind of thermal grease, and how do I apply it?
More Information
CPU-Z
Sorry, it would be a program you download. It wouldn't be installed on your pc.
Here's a guide you could look at for installing HSF:
CPU/HSF/thermal paste installation guide
It is based up on the brand thermal compound Arctic Silver.
It would be similar to reg white thermal paste.
Profile: Faithful Poster
More Information
Make sure you didn't forget to plug in the 4-pin power connector on your motherboard.
Profile: addict
More Information
Thanks for the links. Is there anything else I should be worried about? All the plugs are working, and lights are on. It shouldnt be the HDD right?
Profile: addict
More Information
I did reconnect both the 20, and 4 pin. the fan, hdd, cd rom-only 1, and on switch. Everything is connected the way it should. It has got to be something wiht the cpu.
My cpu is P4 2.6ghz. Not that special, expecially for gaming. Thats why I wanted to upgrade it.
UC7
Profile: journeyman
More Information
This might seem like a stupid response, but usually it is the simplest of things that screw up a reassembly.
1) Did you make sure that when you put everything back together, the power switch connector for the MB was in place?
2) Did you make sure that both power supply plugs for the MB are connected correctly?
3) Did it not work at all? or did it turn on, and then off shortly after - if so, seating the heatsink and fan correctly can avoid overheating that can cause quick shutoff.
Just some quick ideas. Maybe you have already thought of them.
Heck, by the time I posted this, you already answered some of it.
It seems odd that you cannot even get your PC to POST.
You should be able to turn it on even with the HD disconnected.
Profile: addict
More Information
Yep, everything is back together. I did not take any hardware out, just the heatsink and PSu. Unplugged the Mobo pins, main fan, and everything else that went with the PSU. The power switch is plugged in, but I think that is the reason, because when I first pulled it out, I dont know why, it made a funny sound.
It does not turn on at all. Not even a second.
More Information
Is it a socket 478 (Pins on the chip) or a 775 (Pins on the motherboard socket)?
Either way, make sure there are no bent pins.
Try clearing the CMOS - should be an option in your BIOS setup - if not then there should be a jumper on your motherboard.
Profile: addict
More Information
Its a 478. I havent taken the cpu out, never have, little too scared. If that is what I have to do, I will try it.
What is CMOS? I cant get into the BIOS because the pc doesnt even come on.
Where would the jumper be?
UC7
Profile: journeyman
More Information
Here's another quick one...
Is this the same PSU or a new one that you just installed?
If it is a new PSU, give the old one a try again (you dont need to install it, but have it nearby the board.) If it is a new PSU, there is a possibility of an error with the PSU, or maybe a bad wire.
If it is the same PSU as before, it is unlikely that it all of a sudden failed.
More Information
Quote :
Do you mean the Power Switch header on the mobo? You can try bypassing the switch by connecting the pins with the tip of a screwdriver.
Profile: addict
More Information
No, its the same PSU, same eveything. I did not install anything new.
More Information
Quote :
What is the model number? Can check Dell's site to see if they have a manual online to show where the jumper is.
Profile: addict
More Information
By power switch, I mean the cord that leads from the MOBO to the button to turn it on.
Profile: addict
More Information
Do you mean the motherboard model #?
More Information
No, the computer name and model number. For example: Dimension C521
UC7
Profile: journeyman
More Information
Was this power switch connection broken when you removed the connector? It should have 2 metal posts that are sticking up from the MB. Usually these are very close to the connections for the HD LED, POWER RESET.
Profile: addict
More Information
Dimension 3000.
Profile: addict
More Information
It was working fine before I unplugged it. I want to make this clear, it is the cord from the MOBO to the button to turn it on.
It is a 9 pin connector. I have 2 on my MOBO, only unplugged one.
UC7
Profile: journeyman
More Information
That is not the connector to the power button. I am referring to the conection with the wire that leads to the power button on the front of the case. This wire is extremely small.
Profile: Forum Fixture
More Information
Quote :
Exit!
Another new avatar I see. You continue to amaze me. I had believed for years that I was only one of 5 people who had ever known the Kamp Komedy "Killer Klowns from Outer Space"
More Information
n°1282751
10-06-2006 at 02:22:38 AM
