Before I begin, thanks for your time.
Ok, so I'm finally building a new system, but one of the things I want to be able to build into my system is longevity. I'm planning on building a Mid to High end system now, but there are some things I want out of it in the future Most of these things come down to having a Motherboard that will support these things.
Here's the kicker though, If significant longevity can be achived by waiting till say Thanksgiving or so, I can wait that long, but thats the cutoff point really
#1 I am not going with SLI or Crossfire yet. I want the capability to, because well, if I buy a $300 dollar video card now, and decide a year from now to upgrade I can buy the same card for $150 and almost double my proformace (in some area's yes I know in others it does almost nothing ...)
#2 Intel Quad Support, or atleast a damn good chance at it via flashing the BIOS
Actually after those two, most motherboards will cut the mustard, maybe the ability to run DDR2 faster than 800MHz, but that will do for now. I'm not terribly concerned with overclocking, though that may be a cheap option for future upgrading ($50 for a new heat sink instead of $400 for a new processor)
here's the system I've been thinking of so far:
Intel E6600
Mobo: ? maybe Asus with the NForce 590 chipset (When available) ?
BFG Geforce 7950GT 512MB (Factory Overclocked)
2xWD 74GB Raptors RAID 0 (Fell in love with RAID with my current system)
2x1 GB DDR2 800 G.Skill 4-4-4-12
DVD burner ... case ... yada yada yada.
Thanks for your response and Motherboard suggestions, if you have any suggestions on the system I'm open. Thanks
Intel E6600
