Hi there.
Iv recently installed a Gigabyte 3D galaxy cooling system and am very happy with it. I now also want to include my GPU (to overclock) and Northbridge (because its noisy) into the setup.
The problem Im having is finding Blocks that have 1/2" connectors. I would like to connect them in series with the current system so moving down in size (to 3/8 for example) is not really an option as it restricts flow. I also considered using splitters and going down to 2 1/2" inch paths for GPU and Chpiset but I thing my case will be overwhelmed with connectors and Y pices.
I was wondering if anyone who has built a half inch system has come up with a solution. (I have looked at dangerden but they ae a bit on the pricy side).
By the way its a 7900GT and an ECS Nforce4 a939 mother board.
Thanks very much
Thanks very much
