Archived from groups: microsoft.public.windowsxp.basics (More info?)
i have a hp laptop running windows xp and have a problem with the internal
modem
when i go to device manager it reports that the modem is installed
correctly - and when i test the modem it responds ok, but when i try to
connect to the internet i get a no dial tone response
i have tried different phone lines, different internet accounts and
different phone cables but with the same response - i have also installed an
external modem and this works fine with the different phone lines, internet
accounts and phone cables
is it possible that the socket where you plug in the phone cable is damaged
which means that as far as the computer is concerned the modem is
functioning ok?
any help would be much appreciated
andrew
Sponsored Links
yes the modem is working ok otherwise it would come up in device manger as a
yellow error.
windows is taking ok and the modem is "ok" but the phone line is either not
working but rember you have to do it from the main line and remeber you need
microfilters!!
hope it goes ok!
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > modem problem
There are 465 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
