DNS problem with ActiveSync 3.8 Pass-Through
Last response: in Cell Phones & Smartphones
Anonymous
January 30, 2005 6:05:01 AM
Archived from groups: microsoft.public.pocketpc (More info?)
I installed ActiveSync 3.8 a few weeks ago . Since then, when I connect from
the PPC to the Internet via the USB cradle Pass-Through , I get a DNS error
of IP not found. If I surf with an IP address I have no problem. I have a
simillar problem with email setting - won't recognize pop/smtp addresses .
I used a third party software to check my settings while in Pass-through:
IP Address: 192.168.55.101
Subnet : 255.255.255.0
Default Gateway: 192.168.55.100
DNS Servers: 127.0.0.1
WINS Proxy: No
Can anyone figure out what the problem is ? Is it because of v3.8 ?
Thanks
Anonymous
January 31, 2005 10:29:30 AM
Do you have a personal firewall software installed? Since the ActiveSync
update have you changed the configuration to allow ActiveSync connections?
Mauricio Freitas, Microsoft MVP Mobile Devices
http://www.geekzone.co.nz
http://www.geekmac.com
Bluetooth guides: http://www.geekzone.co.nz/content.asp?contentid=449
Geekzone Software Store: http://www.geekzone.co.nz/store
"Eran" <Eran@discussions.microsoft.com> wrote in message
news:5BCF1EF2-8975-4803-B615-D19F79B21C78@microsoft.com...
>from
> error
> WINS Proxy: No
> Thanks
Anonymous
January 31, 2005 10:29:31 AM
I have Norton AV 2005 with worm protection. I enabled the new Activesync to
path through. I also tried disabling the firewall - no change. In the past I
had the same firewall without a problem. Besides, as I explained, it appears
to be a DNS problem, because I can surf with IP address.
Thanks
> >from
> > error
> > WINS Proxy: No
> > Thanks
Anonymous
January 31, 2005 2:40:39 PM
The DNS problem can still be a firewall problem - the server may not be
receiving the UDP requests to DNS.
Some firewalls store a checksum for each app authorised to access network
resources. Perhaps Activesync 3.8 is blocked since it's different from
ActiveSync 3.7? I'd check the Windows XP firewall first, then AV2005, then
firewall.
Mauricio Freitas
MS MVP Mobile Devices
Bluetooth Guides: http://www.geekzone.co.nz/content.asp?contentid=449
Performance Center: http://www.geekzone.co.nz/content.asp?ContentId=2028
news:327A0130-DFA8-4901-A6D1-F43E262BA57B@microsoft.com...
>to
> I
> appears
> Thanks
>> connections?
>> >from
>> > error
>> > a
>> > addresses .
>> > Pass-through:
>> > WINS Proxy: No
>> > Thanks
Anonymous
January 31, 2005 2:40:40 PM
You are correct, it is a firewall problem. If I disable Norton Worm
Protection (NWP)and Windows XP firewall - I can surf. If I enable the XP
firewall with ActiveSync Exeptions - I can still surf. But when I Enable
Norton Worm Protection ( I have deleted and add the new Activesync to NWP )
The DNS problem returns. I have set NWP to allow all activesync connections -
but it still didn't work. Finally I added a rule to allow UDP connections on
port 53 and that solved it. Is there a safer way?
> firewall.
> Mauricio Freitas
> >to
> > I
> > appears
> > Thanks
> >> connections?
> >> >from
> >> > error
> >> > a
> >> > addresses .
> >> > Pass-through:
> >> > WINS Proxy: No
> >> > Thanks
Anonymous
February 1, 2005 3:43:08 AM
The rule for UDP should be ok. Are you connected directly to the Internet,
or is it through a router?
news:2B772A8E-F196-43E7-8B89-1ABB958BB6C7@microsoft.com...
> NWP )
> connections -
> on
>> then
>> firewall.
>> Mauricio Freitas
>> >Activesync
>> >to
>> > past
>> > I
>> > appears
>> > Thanks
>> >> ActiveSync
>> >> connections?
>> >> >connect
>> >> >from
>> >> > DNS
>> >> > error
>> >> > have
>> >> > a
>> >> > addresses .
>> >> > Pass-through:
>> >> > WINS Proxy: No
>> >> > Thanks
Anonymous
February 1, 2005 3:43:09 AM
I'm connected through a Linksys router.
> > NWP )
> > connections -
> > on
> >> then
> >> firewall.
> >> Mauricio Freitas
> >> >Activesync
> >> >to
> >> > past
> >> > I
> >> > appears
> >> > Thanks
> >> >> ActiveSync
> >> >> connections?
> >> >> >connect
> >> >> >from
> >> >> > DNS
> >> >> > error
> >> >> > have
> >> >> > a
> >> >> > addresses .
> >> >> > Pass-through:
> >> >> > WINS Proxy: No
> >> >> > Thanks
Anonymous
February 1, 2005 10:52:55 AM
That should be fine them.
news:778A5561-9BEB-4D58-ACB9-2AD139D6B8D3@microsoft.com...
>> Internet,
>> > XP
>> > Enable
>> > NWP )
>> > connections -
>> > connections
>> > on
>> >> be
>> >> network
>> >> then
>> >> firewall.
>> >> Mauricio Freitas
>> >> Performance Center:
>> >> >Activesync
>> >> >to
>> >> > the
>> >> > past
>> >> > I
>> >> > it
>> >> > appears
>> >> > Thanks
>> >> >> ActiveSync
>> >> >> connections?
>> >> >> Bluetooth guides:
>> >> >> >connect
>> >> >> >from
>> >> >> > DNS
>> >> >> > error
>> >> >> > I
>> >> >> > have
>> >> >> > a
>> >> >> > addresses .
>> >> >> > Pass-through:
>> >> >> > WINS Proxy: No
>> >> >> > Thanks
