Fujitsu Siemens Amilo pro v3405 wireless connection always on
Dear all,
My laptop Fujitsu Siemens Amilo pro v3405 wireless connection always on after upgrading to Genine Windows 7............I ca not switch of from the wireless bottom nor by Fn F10...................... need your utmost help please
Thanks a lot.
Nagy- Port Said - Egypt
3 answers Last reply
More about fujitsu siemens amilo v3405 wireless connection
  1. Did you re-install all of the wireless and option button drivers after installing Win 7?
  2. Dear hang-the-9
    In fact I inserted the disk which came with the laptop, which was with XP run and installed all its contents, but after W7, reads " All necessary drivers & updates are OK".......So I did not do more.......
    Best regards
    Nagy
  3. Sigmateam said:
    Dear hang-the-9
    Best regards
    Nagy
    Your XP disk is useless after you installed Windows 7. Look in device manager for anything not installed properly.
Wireless Connection Fujitsu Siemens Windows 7
