OS & CD Problems
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have a home & an office computer with XP. I took two
formatted CDs with files already on them to my office
computer, which also has a floppy drive, so I could copy
files from the floppy to the CD. I copied the files with
no problems with 90% of the disk space still free.
However, when i inserted the CDs back into my home
computer, I now have a file on both of them named "Non-
Allocatable Space," a read-only hidden file with 0 Bytes
and both created on the same day of the office copying.
As a result of this file, both CDs have 0% free space and
i am unable to reformat them, change file names, etc. I
tried to remove the file but receive a message, which
states that cannot delete, saying the CD is read only &
cannot copy or move files to CD - although i'm not trying
to do the latter. Please help.
3 answers Last reply
More about problems
  1. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    If you copied files to the CD by saving directly to the CD or by dragging
    and dropping the files directly to CD, you must have a packet writing
    application installed on that system, both Nero and Roxio's Easy CD Creator
    and Easy Media Creator include such an app in their default install. If
    that is the case, assuming the home system does not have that type of
    application installed, it's possible that is the source of the problem and
    the solution would be to install that application on the home PC.
    Michael Solomon MS-MVP
    Windows Shell/User
    Backup is a PC User's Best Friend
    DTS-L.Org: http://www.dts-l.org/
    "donna" <anonymous@discussions.microsoft.com> wrote in message
    news:19f101c4d23f$e90b6ff0$a501280a@phx.gbl...
  2. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    i forgot to add that i copied the files from the floppy
    directly onto the CD using Windows Explorer. There is a
    program on the office computer for doing this but i have
    never used it. It believe this may be important. Thanks.
    >-----Original Message-----
    CD or by dragging
    packet writing
    default install. If
    that type of
    of the problem and
    home PC.
    >Windows Shell/User
    message
    copy
    with
    Bytes
    and
    trying
  3. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Yes, it is important and that pretty much conforms my original response to
    you. The application installed on the Office computer enables packet
    writing and if you don't have a packet writing application installed on your
    home system, very often it cannot read disks created in that fashion.
    Often, the application maker has a free reader that you can install on your
    system although I'm not wild about them as they can sometimes be
    problematic. Nonetheless, if you find the name of the application on the
    Office computer, check the app's website for the reader. It may be called a
    UDF reader or they may have some other name for it. Ideally, it would be
    best to have some such packet writing application installed on your system.
    Windows Shell/User
    news:087e01c4d402$67080b20$a501280a@phx.gbl...
    > CD or by dragging
    > packet writing
    > default install. If
    > that type of
    > of the problem and
    > home PC.
    >>Windows Shell/User
    > message
    > copy
    > with
    > Bytes
    > and
    > trying
Computers CD-Rom Office Windows XP
