Hi,
I bought a PC tower with a D945GPM motherboard (775 socket) that has a Foxconn cpu fan on what I assume must be a Foxconn Heatsink. The cpu chip is a Pentium D 840 90nm technology dual core. It sits in a tower case with one 90mm fan in the back and a 350w power supply in the back at the top of the tower. I downloaded the Intel desktop utilitys and ran a stress test for 8 hours during the day. The room temperature got as high as 85 degrees fahrenheit. The Intel utilities (and I also used speedfan) shows the CPU temperature reaching 87 degrees Celsius. Intel specs say the processor case should not go over 69.8 degrees and the motherboard specs say the heatsink weight should not exceed 450 grams. I removed the heatsink and checked that thermal paste was applied and it was. The footprint of the thermal paste seems to indicate that the cpu chip or the heatsink may have a slight curvature to it as the paste was thicker towards two of the edges of the heatsink but was thin toward the center. I also layed the case on its right side and saw the cpu temperatures drop as much as 7 degrees Celsius. I thought that was really weird and it made me wonder if a horizontal desktop case might be better than a tower case for cooling. There is a shroud from the left side of the case that meets up with the cpu fan to pull in cool air from outside the case and the cpu fan blows air into the heatsink toward the motherboard.
I am looking for a new case and cpu/heatsink to to replace the ones I have and would like to hear suggestions from the members here.
