I recently decided to upgrade from an 80GB PATA to a 250GB SATAII drive.
After installing MCE2005 onto the new drive Ive realised that I can no longer bring the machine out of hibernation or S3.
Motherboard settings are definitely set to S3 in the power menu but the computer refuses to come out of either S3 or S4, instead deciding to load as if completely shudown.
The symptoms are: When told to standby, the machine logs off and then displays the blue windows screen stating it is entering standby. The LED on the front changes from green to orange but only for a split second before it goes out and the machine apparently appears dead. On pressing the power button the machine starts as if it had been completely shutdown.
Ive read that SATAII drives have had problems with S3 due to longer spin up times.
Is this true? Does anybody have any ideas how I can get the machine to do S3 and S4 properly as it did before I changed the HDD.
SPEC: MSI K8NGM2-FID
250GB Samsung SP2504C
