Hi i hope someone can help me.
A couple of nights ago i turned my computer on to be greeted by a big bang and a blue spark out the back!. After this the fuse had blown in the plug and the computer would no longer turn on.
So i went and bought a new power supply and sent the old one back.
NOW i have installed the new power supply but here are my problems.
1. The computer will not start when the sata power is connected to the HD's
2. It will start up when the HD's are unplugged(i.e the fans start lights etc) but nothing happens on screen i get one long beep, and i can't count, two or three short beeps from the motherboard. But nothing really happens after that.
I have check the video card and the fan is working on it and has a small green light lit at the end of the board nr the PCI-E Power supply connector.
So have i fried the Graphics card? have both the HD's failed? Is my RAM ok. I have no way of testing all these thing really so am stuck.
I really dont understand why it wont start when sata power is plugged in and does when its not!!!?? ??$%^
I have tried a couple of power supplies and all of them do the same thing when i connect the sata power to the HD's
Can anyone help?
SPEC:
Motherboard: Gigabyte GA-8N-SLi pro
Processor: Pentium D 805
Ram: 2GB Corsair (2x 1GB sticks)
HD - 250gb Seagate
HD - 200gb Maxtor
Video card - PCI-E NVIDA 256mb 6800 GT
2x Quiet Pc fans 80mm & 120mm
Also Zalman Heatsink Flower Fan
Also have 2 x LG DVD RW RAM drives
and Creatvie Audigy 2 that require power.
Thanks to anyone who can give me a hand!
Nathan
Can anyone help?
SPEC:
HD - 250gb Seagate
HD - 200gb Maxtor
Nathan
