shut down problem
G
Guest
Guest
Hello...i recently built a AMD Athlon with a Socket A motherboard A7M266....i installed an 98 o/s on it....the problem is that i can't shut down....once i try to shut down, it would reboot....i just want to know the source of this dilemma...is it because of the BIOS or the power management....PLEASE HELP!!!!
aster
154
It sounds like a software problem. Check what programs are running when you try to shut down using Ctrl-Alt-Del. Sometimes even a corrept audio file at exit can make win98 hang.
