Hi All,
I just built a computer with a Pentium 805 D inside. I am trying to monitor the temps from windows but am not having luck. My bios says over 50 C for the CPU but then when I get into windows I have all sorts of problems. Hardware Sensor Monitor says Mainboard 27C and CPU 38C when no load, but then under load, the Mainboard shootsu p to around 50C and CPU stays close to 40C. This doesnt make sense to me even if its switched. Speedfan says HD0 41C and Temp1 30C under no load, which doesn't match either of the Hmonitor temps. What temp do I believe? I just want a reliable temperature so I know if I can overclock. Thanks all.
Stro
Stro
