I need help deciding between three video cards, my budget is $50 or below (I'm really short on cash, but high on gaming).
The games I play are mostly CS: Source, Madden 07, NBA 07, and occasionally Sims 2.
CS I plan to play on high setting at 100 fps, Madden and NBA should be no problem, and I give up on good Sims 2 graphics due to lack of monetary status.
I've narrowed it down to these three:
PNY GeForce 6600 256 MB, 300 mhz core, 500 mhz RAM, 8 pixel pipelines, 128 bit: http://www.newegg.com/Product/Product.asp?Item=N82E16814133154
BIOSTAR GeForce 7300LE 128 MB, 450 mhz core, 533 mhz RAM, 4 pix. pipe., 64 bit: http://www.newegg.com/Product/Product.asp?Item=N82E16814141030
GIGABYTE Radeon X1300 128 MB, 450 mhz core, 700 mhz RAM, 4 pix. pipe., 64 bit: http://www.newegg.com/Product/Product.asp?Item=N82E16814125027
I would have picked the 6600 had its core speed not been 150 mhz slower, I woulda picked the 7300 or x1300 had their pix pipe and bit been higher.
Any help would be appreciated!
Oh and it's an HP, not sure about the power supply, but these aren't very power-hungry video cards right?
Specs:
AMD Athlon 64 X2 4200+, 2.0 ghz
2 x 512 MB PC3200 RAM
250 GB 7200 rpm
ATI Radeon Xpress 200 :-(
Specs:
250 GB 7200 rpm
