system specs:
Gigabyte GA 965P-S3 - MB
E6600 - CPU
2 gigs Corsair DDR2
Sapphire X1900XT
WD Raptor 150gb
Win XP Pro
After I was done building the computer it started up fine, formated hard drive, installed windows. PLayed a little pinball. Everything all good. So I installed just the chipset drivers which I d\led from another computer and burned to a cd. The install went fine, when it was finished it asked me to reboot the computer. So I clicked on okay, nothing happend for about 30 seconds, then came the blue screeen of death. So I restarted my computer, 1st problem that started was my hard drive was not reconized anymore. So I turned the computer off, stuck a new sata wire on, plugged it into a differnt SATA port. Started the computer, picked up the hard drive, went into windows, and know my keyboard and mouse wont work at all. I restarted again, found my keyboard works fine within the bios. I thought well maybe if I reinstall windows, I could just reformat and start over again. But my keyboard will not work at all after the initial bios screen. I cannot push a key to boot to the cd. I tried all the usb ports, tried differnt keyboards and mice. Used adaptors to try the ond mouse and keyboard ports. nothing works. I even tried a differnt hard drive, but still the mouse and keyboard dont work. thanks for any help.
E6600 - CPU
2 gigs Corsair DDR2
Sapphire X1900XT
WD Raptor 150gb
Win XP Pro
