ok, we know the sound card works - an audigy 2 zs, tested it in another comp
this does not work at all in the comp.
onboard sound gives just annoying tones if it works at all.
makes me to believe the motherboard is bad, anyone have an idea.
specs on comp:
P4 2.2
half gig of ram (generic i think - bought from comp usa)
ABIT sd7-533 motherboard
this comp is 4+ years old and dusty. ram is about 1 year old.
dust killed another mb recently, which also makes me believe the mb is toast.
thanks for the input.
specs on comp:
P4 2.2
