MSI 661FM2-LSR Motherboard/memory help!
i added 1gb pc 3200 cl2, 184-pin ram to the MSI 661FM2-LSR Motherboard, and all it did was beep at me. so i turned the pc off and put the other stick back in it. Now the computer will just start up, the monitor willn't turn on.
1 answer Last reply
More about 661fm2 motherboard memory help
  1. Sounds like you accidentally disconnected something, or forgot to reconnect something. Unplug and replug *all* the power connectors, and use some canned air to blow all the dust off the MB and out of the case.
Memory Motherboards MSI-Microstar
