The 1 Month Problem!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - The 1 Month Problem!
Hello all... been visting this site for a year a decided to join. So anyway, my PC will not start up. Anyway here is the problem, I cleaned out my old computer my older brother gave me which is about 5 years old (don't worry, I'll give you the specs).
So, I cleaned it out (yes this is dumb) the inside of the case and the fans with a vacuum, and the rest with q-tips. So after I was done cleaning it I powered it on... and it everything turned, the HD, fans, DVD drive and CD drive worked and the HD life was on, non stop, and it didn't stop, no blinking. Also, there was no beep and the monitor stayed in power save mode with the amber light.
So I decided that the GPU broke. So I went from a GeForce 2 GTS 32mb, to a 9700 Pro 128mb. Tonight, I put the 9700 Pro in... and it did the same thing a it did about a month ago. I think it might be the power supply, but I'm not sure, all I want is to just get the thing running.
Specs:
-AMD Athlon 1200+
-55 GB Maxtor HD
-256mb of 266mhz DDR ram
-Radeon 9700 Pro
-CD and DVD drive
-300 watt power supply
This computer is a Compaq Presario 7000 :)
Sponsored Links
More likely something got disconnected, or the hard drive is corrupt...
Can you see the BIOS post onscreen? Are there any beeps while booting?
Reply to RichPLS
Nope... nothing appears on screen, the monitor acts like it isn't even connected to the computer. Also, there wasn't a single beep when I turned it on.
Reply to MasterMike5280
Check the monitor cable, make sure there aren't any bent pins.
Test the monitor on a different computer.
Test a different monitor on the troubled computer.
Did you remove the heatsink from the CPU while cleaning? If you did, then did you re-apply thermal grease properly?
Make sure the memory is seated properly.
Make sure all cables from the power supply are seated properly.
Make sure the hard drive cables are seated properly and in the correct orientation (not connected backward)
Try unplugging the CD and DVD drives in case it is a power issue.
Cleaning out the PC with a vacuum is a good idea, better than using canned air which just blows the dust around and under the motherboard, into empty slots and into the power supply.
Good luck. 8)
Reply to threep
I didn't remove the heatsink, there are no bent pins, I can't test the monitor on another PC for reasons, the memory is in right, HD cables, and CD and DVD drive wires are fine... and for removing the wires from the CD and DVD drives.... their stuck, and I can't remove them. So, it might be the power supply...
Cleaning out a computer with a vacuum is a vary bad idea DO NOT DO THAT! The electrostatic that will discharge in your computer will most likely fry things. Canned air is hte best way to clean it out. Take out everything in the computer and clean it piece by piece. Also anti static wipes is a easy way to clean alot of things in a computer.
Reply to EnFoRceR22
Quote :
Haha, there's a reason people don't vacuum their PC, because it can create static electricity and fry your crap.
**Edit: He ^^ beat me to it.
Reply to melf26
I realized that after I was done cleaning it. :cry:
Sorry i typed it as fast as i could :(
Reply to EnFoRceR22
If one has a good building ground, and one's wall plate is connected properly and the power supply is performing as it should (and turned off but still plugged in) then vacuuming is no worse (or better) than canned air. If any of the above conditions are less than optimal, then either method is bad. Esd is more about moving the dust than about how one does it. And an antistatic mat that is not properly grounded will not help either... Nor will a wrist strap that's not properly grounded...
Reply to croc
All things you most likely cannot conferm and shouldnt trust because of that fact. I dont like to play games with my hardware and i dont recomend others do either. The power supply is suppose to protect the computer againced serges getting to the hardware i dont trust it to stop them coming from the hardware its self. Canned air doesnt create more as the electric componants in a vacuum will. I never recommend cleaning a computer while it still resides in the case however.
Reply to EnFoRceR22
http://multimedia.mmm.com/mws/medi [...] 8rCOrrrrQ-
One of many links on 3m's website relating to esd... There are other sites, 3m's is just handy.
Basically, get properly grounded or your stuff's dead. cmos is so sensitive that the rf from your mobile will fry it. From two meters....
Reply to croc
Quote :
Specs:
-AMD Athlon 1200+
-55 GB Maxtor HD
-Radeon 9700 Pro
-CD and DVD drive
Sorry, but this equals place in garbage and save for something decent. I had a Gateway PC from 1999. It was a PIII 500 Mhz (P.O.S.) with 128 mb ram and a dying 17" CRT. I sold it a few months ago to a sucker for $175. Truthfully, you might try selling parts on ebay and get something out of it and put towards something that won't be frustrating to use.
Reply to Cartman0123
might just be me but i dont think they ever made a 1200+ CPU
Reply to EnFoRceR22
I really have no money to get a new PC, I'm turning 14 in a month and I'll be able to get a job, but until then, I have to deal with this. The 1200+ is 1.192GHz... and yes... I know never to use a vacuum now... but can anyone know the reason why this computer doesn't boot?... please.
i see three possible reasons:
-your mobo is dead (bios) :(
-your psu is dead :(
-you made a stupid mistake with cabling and stuff :D
*hoping
it's the third....*
Reply to exarrkun
Quote :
Hello all...
Specs:
-AMD Athlon 1200+
-55 GB Maxtor HD
-Radeon 9700 Pro
-CD and DVD drive
Most likely the ram stick was bumped, they can lose connectivity very easily with the slightest movement. That has happened to me many times with Sdram, leaving the same symptoms you describe. Remove the memory stick, make sure the pins and Dimm socket are free of dust, then reinsert it, pushing on the stick directly until the two snaps close over the ends.
Reply to BustedSony
Sounds more like a 1200ghz cpu not a 1200+ would be clocked more like 1050ghz i cannot find refference to a 1200+ anywhere on the net. That said its a thunderbird cpu they tend to get vary hot whats your cooling like? do you know if the cooling has been compramised? That sort of problem normaly isnt caused by a memory stick being bad or loose it would post and beep in that case. Have you tried taring it apart and putting it together on a wooden surface to see if it posts out of the case? I would have to agree with exarrkun either that or its grounded somehow.
Reply to EnFoRceR22
I'm pretty sure the MoBo is dead (don't know how it died) because I disconnected the CD and DVD drive and reinserted the memory, but still when I power it on, everything turns on and starts up, except, there is no beep. When I disconnect the monitor from the computer, it says there is no signal, so the monitor is working. Well, I think I'm all out of options. Thanks for the help.
Also, I just took out the memory stick and started up the computer, there was no beeps either, so that confirms the MoBo is dead. :(
that doesnt really mean int he motherboard the athlon 1200 along with that video card could be exceding that crappy PSU that comes in OEM computers. 300watt but not a 300watt thats actualy 200watt. Like i siad your problem is most likely not your memory your problem doesnt consist of the problems of bad memory. It is however a good thing you were able to test your componants in another computer. If you have another computer see how much of your stuff you can test. Hell if you could test the video and cpu in another system with your current psu that would narrow it down a bit ;)
Reply to EnFoRceR22
Quote :
ESD Fundamentals
Reply to baladorr
i had the same symptoms when i fried my mobo...(well not fried more like borke :D ) the comp would not make a sound but the orange / amber light would turn on....then the monitor would go to sleep, not showing a thing
Reply to diox8tony
Quote :
Thats not a good sign...
Also, I can't test the CPU, and I know the graphics card is working.
like i said before in a post exarrkun has the most likely suspects in your case. maybe you have a computer store near by that could put the mobo onto a different psu? if that doesnt work put the cpu on another mobo would be really easy to say what it is once you tested it all. Some shops around here are even nice enough to do something so little with out charging.
Reply to EnFoRceR22
Quote :
I would like one of those :lol:
Reply to FeareX
Rotfl took me a minute to notice that typo XD mhz SORRY! wouldnt that make it a 1.2thz chip? lol
Reply to EnFoRceR22
lol
how much would such a chip cost... :lol:
however, about the mobo
i suspected it because it once happened to me :roll:
when it's a memory problem, you usually have a long beeeeeeeeeeeeep
(trust me :D )
Reply to exarrkun
one long three short beeps normaly indicates memory :o
Reply to EnFoRceR22
Well, I have a computer repair place almost right near me, so I'll bring the thing there.
Quote :
Ok lets say the monitor works, and you connected everything right. Video card works cause you switched it out you said.
THE ONLY reason it wouldnt post is
1. Motherboard is fryed (thats what i think)
2. Power supply is not giving enough voltage to post but is providing voltage for the fans. (i think this is unlikely though)
Reply to shata
its not as unlikely as you might think. 300watt power supply is the recomended wattage for that cpu not to mention his video card wants a nice bit of power. Taking in account his system is OEM and they seriously skimp on those power supplys its probly closer to 200watt. I have had two instances that the fans power up but hte computer wouldnt post replacing the power supply fixed it. fans use vary var vary little power however things like cpu, video card, cd roms, and hard drives take considerable power to even start up. Course that doesnt even matter untill diagnostic process will provide the problem those are however the two most likely problems.
Reply to EnFoRceR22
My advice is try the following:
Unplug all devices, ram, video and any PCI cards, disk drive cables. If you connect an IDE cable the worng way your machine will not boot!!!
Boot system, make sure speaker wire is connected!!!!! :oops:
If you get no system beeps at all then your mobo is most likely dead. That's not so bas as ebay is a good source of older mobo's and you'll only need to get same chipset in order to avoid XP reinstall.
If you get system beeps then mobo should be OK. Insert RAM and reboot. If you get beeps then insert VGA and reboot. If you get beeps now then most likely RAM or VGA is dead. THe beeps are different for VGA and RAM problems, I cant remember for sure but believe that long beeps indicate a RAM problem.
If machine now boots then most likely cause was a drive cable round wrong way, remember red stripe on cable indicates pin 1.
You can now insert cables for disk drives (one at a time, forget floppy!).
Baiscally you have to narrow down the problem by adding one device at a time.
Hope that helps, hope you get it working.
If all else fails then contact a small local PC repair company and tell them that you are a poor 14 year old and wondered if they had any old systems going spare, dont forget to mention your PC is broke, you never know they might be the charitable type :P
Reply to monkeymanuk
You know how to connect the system speaker on your motherboard? im assuming its already connected since its a OEM. should be some documentation on thier website about that model.
Reply to EnFoRceR22
As you are trying "long shot" cures for this PC, I recommend pulling the power cable from the wall, then popping the BIOS backup battery from the motherboard for a few minutes. Even though it's doubtful to be a bios issue I have seen a dead machine come back to life this way.
I also recommend trying to boot the machine with all the drives disconnected, and just power to the motherboard. If it's a faulty hard drive ( and yes I have seen a faulty HD stop a machine booting ) or CD of floppy then this gives you every chance of getting a bios screen to come up.
Like many people on this board I've spent many an hour trying to rectify issues that have arisen once I decided to open the case for a little cleaning or tidying. Sometimes it pays to leave alone if the thing appears to be working okay.
I agree with the people who said earlier that vacuuming the PC was one of the worst things you could do. It really is an easy way to create electrostic charge that is in the thousands of volts. Even though it has a tiny current a discharge of ectrostatic energy can blow holes inside delicate electronics. A really good technician uses an insulating mat and wrist strap for that kind of work.
I hope you have a luck with the computer.
Reply to GavinLeigh
Well... I really just tried almost everything and... I'm going to wait till I have some free time and bring it to a shop. :|
When you do and if they say its the motherboard ask if they have a epromm tester if its simple as the bios google bios replacment chips and get a new one youll be set. If not depends on what is said :-/
Reply to EnFoRceR22
Quote :
mmm
guess it depends of the mobo brand
(or my memory it was a long time ago :) )
Reply to exarrkun
Thnking about this from a logical point of view.... don't spend any more time on the PC.
Just go and offer to wash people's cars for $10 and save up the cash for a new PC. As the guy earlier said... you can always try to sell the good parts on Ebay. I once bought a box of computer parts at a yard sale for $22 and sold them for $400.
I agree with Enforcer22 about the power supply, I work at a computer repair shop and we see dead power supplies all the time... and some only fail partially. Sometimes you lose the 5v feed but the 12v still works, this can make things difficult to diagnose which is why we have a psu tester for them. Often a flaky machine, with intermittent issues can be made stable again by a new power supply.
But then we are back to how much time and money to throw at a 1200mhz machine. I don't think you should be spending more than $10 on fixing this.
Reply to GavinLeigh
It actualy has more to do with the bios then mobo some memory beeps it was continued long beeps.
Reply to EnFoRceR22
Quote :
thanks for the info
didn't knew that :)
Reply to exarrkun
there is also vary little info on it that i was able to find on the net. So gl if your trying to figure them out but if you do im more then interested in knowing :D.
Reply to EnFoRceR22
Quote :
lol
thank you o mighty google user :D
Reply to exarrkun
heh if i was i think i would have found it. Believe it or not i never used google till about 2 months ago.
Reply to EnFoRceR22
Quote :
u can't mean that!!! 8O 8O 8O
are you from mars??? :)
Reply to exarrkun
haha yeah i hardly used search engines and if by chance i did i used webcrawler.
Reply to EnFoRceR22
Quote :
webcrawler...
believe it or not but i never heard of that one before :lol:
(omg we are spamming this forum :) )
Reply to exarrkun
rotfl spam spam spam spam yeah check it out its not a bad engine not exactly why i use google now maybe cuz its easyer to type lol.
Reply to EnFoRceR22
yeah is kinda cool
finds other things than google
:twisted: now i can even become smarter :twisted:
Reply to exarrkun
Previous
1 2
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > The 1 Month Problem!
There are 1258 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
