Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem overclocking x1900 Crossifre?
Forum Graphic & Displays : Graphics Cards - Problem overclocking x1900 Crossifre?
I have an x1900xtx, x1900crossfire with an a8r32mvp. When I use the CCC to overclock my cards my system will freeze during 3dmark06. I have tried pushing it up a little at a time, also tried using the automated overclock utility. My question is I have pcie frequency, peg link mode, pcie voltage and some other settings in my bios, I was hoping that someone has any suggestions on setting for those. Thank you
Currently peg link is disabled, peg buffer length is on auto and pcie voltage is on 1.4, When I had an x1900xtx by itself the card would overclock just fine but now that I am running crossfire that is when all the problems with overclocking have started.
Sponsored Links
sorry i can't really help but i can ask why the hell you feel the need to overclock a crossfire setup. aint the performance enough or something.
oh and are you using the stock coolers. i'm not bashing them just wondering thats all.
also last time i check the CCC only shows up the crossfire card so i'm not sure you can adjust the xtx.
Reply to strangestranger
I dont really know how to answer that. I guess that no matter how fast something is people will always want it to be faster. I would assume that any overclock settings that you apply in the ccc would apply to both cards? any yes I am using the stock coolers. I want to get some aftermarket coolers however I need ones that will blow the hot air out the back of the case and not onto the other card, or liquid cooling of course...it does wonders for my cpu temp.
Reply to ddemaray
perhaps someone will know if overclocks affect both cards but i am not sure as the clocks on each card are different as AFAIK the clocks are not as some believe lowered on the xtx so in fact if you were to over clock the CF edition you could be raisnig the xtx to far.
it is worth looking into, unless someone knows here try the futturemark forums. they are the kind of people that would know about overclocking that kind of setup.
There are 1202 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
