Tom's Hardware > Forum > Overclocking > Graphics Cards > Help! Noobie attempting to overclock a ATI x1900xtx
Forum Overclocking : Graphics Cards - Help! Noobie attempting to overclock a ATI x1900xtx
WOOT! Again I get a chance to be a Noob! What an opportunity to be on the otherside of the fence! But I have very little knowledge in this area, even though I have tried to read allot about the process.
Ok, so I have found my max reliable settings using ATITool at stock voltage. This is often the first step in many guides for OCing the X1900xtx.
I do not shut down ATIEV***.dll or whatever in the task manager, because it seems that ATITool only changes the 3D settings and not the 2D settings. I also seem to have weird behavior when I shut it down. I dont know why I should have to power the 3D processors when I dont use it...
Many people, and guides, recommend shutting this process off, but I cant see any reference talking about it on the ATITool website. It apears that ATITool works with these applications and that it doesnt compete with them anymore.
I have Windows XP(64) and have confirmed that it works with ATITool, by reading the documentation...
I have found my max CPU speeds to be around 730mhz, and Mem speeds at around 810mhz.
I pump up my CPU voltage (the top voltage) to 1.5 (max recommendation for aircooled--I run water cooled), and try to add anymore MHz. It doesnt give me a single additional MHz point. If I push the MHz up a little more, both screens go White, checkered, or slashed.
The highest temp I have received with this card is 50c, and a 59c voltage regulator. The memory runs crazy cold, at around 43c
I have the most recent version of ATITool 25 beta 15 but the voltage settings didnt seem to ever change. I would set it in preferences or save it on the settings voltage sections, but it always seemed to revert back to default.
So I tried ATITool 25 beta 16pre3. Now the voltage settings are saved, and they seem to stay set on the value, but I still dont get any benifit from raising the CPU voltage.
Is the voltages locked on the boards firmware? I hear about flashing new bioses, but I dont know if this will fix my problem... I wouldnt know which one to use. And I worry about there reliablty.
The truth is, I have no Idea what or where to go from here... I am lost
Can anyone help?
Sponsored Links
There are 1293 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
