Another problem
Forum Homebuilt Systems : General Homebuilt - Another problem
Well, my computer seems to just restart and error up when playing certain games.
I thought I had finally fixed it when I flashed the bios to the latest version. Then it came back today.
Sometimes it will restart and sometimes it will just freeze, then a very annoying loud buzzing sound will just keep going for ever.
Any help is greatly appreciated
e6300, gigabyte 965G ds3, 7600GT, 450antec smart power, and 2gb 667 patriot memory.
Sponsored Links
buzzing sound? from where? a internal component, PC speaker, or speakers?
have you tried running memtest? If not, give it a go.
Reply to trixst4r
It was in my headphones, also, when ever I try to run memtest. It gets to a blue screen then my pc restarts itself.
Reply to Yupyup
You have memory problem, Try either setting a lower divider for the ram to slow it down to stabalize it, or take your PC to a local pc repair shop and see if they have a EuroSoft PC Check disk to run diagnostics on it and they will be able to tell you exactly what the problem is. (They will probably charge a bench fee)...That is what I would do, because that is what it seems like you have a problem with!
Best,
3Ball
Reply to 3Ball
Alright thanks.
Reply to Yupyup
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Another problem
There are 1102 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
