I have a Core 2 Duo processor, and right now it's idling at 54C, and get this, goes up to 60C with full load. This is with no overclocking, mind you. I have a Lian Li aluminum case with 4 80mm case fans -- one on top, two near bottom of the front panel, and one in the back. Right now, I am using the stock Intel HSF. The Antec TruePower II 550w PSU has a fan that's pointing down towards the CPU -- that can't be good, right? I can't change that since that's how the PSU is designed... :\ The GPU uses the stock fan, and the RAM has headspreaders.
To give you a good idea of what is going on, here is an image of the internals of my build:
Any how, I have this Zalman CPU fan and some Arctic Silver 5. It is quite big, but do you think I should try to squeeze it in there with the wire mess? Is 54-60 a bad range for Core 2 Duo? (I think it is hearing that the people on New Egg have it in the 40s with the stock HSF) What do you think is causing the bad temperatures? What should I do to fix them? Are the wires the issue?
