Hi guys,
I might seem stupid for doing this; but I was totally caught unawares. I have a HP desktop at home. Its one of those Pentium 4 2.8GHZ HT; with 250 watt Power Supppy, 200gig hard drive etc etc. I had a ATI 9600 card previous; and jsut recently decided that I need to upgrade my video card if nothing else . Ofcourse, after reading the forumz and going to various websites; I saw that 7600GS would fit my price range.
Being the impatient idiot that I am, I ended up being the Card, and as soon as I got my hands on it; tried to fix into into the computer.
Lo and behold; my computer would not boot up; actually it did boot up but there was no image on the screen. Then I was going through the box and manual and it says that requirements = 400 watt power supply. Now the question that comes up next is; WHAT THE HELL KINDA power supply do i need to buy?
I am assuming a ATX power supply? is that right? Its the basic HP motherboard, but I need to buy a 400 watt powersupply. It would be very helpful if you can direct me to the right kind of ps, especially if i can get it in Radioshack or BestBuy or Circuit City, or sTAPLES ..etc...
thanks for your helps
