I am a newb when it comes to overclocking...
Setup...
E6400
GA-965P-DS3
1 Gig XMS 5-5-5-15 Ram
eVGA 7900GT
Followed Wussy's guide...
333x8 (2.66 Ghz)
Vcore of 1.375
Dimm +.2v
Ram to 4-4-4-12 @ 1:1 - 667 Mhz
Turned everything off except TME1
Left all other voltages at normal.
Scenario: Boots up just fine. Runs everything fine. Run Prime95, CPU-Z, and CoreTemp. Ran Prime95 for 5.5 Hours, temp never got above 55C on either core. Prime95 recorded no errors or faults, no indication of anything wrong.
Go to reboot. Doesnt reboot correctly, computer stays on and doesnt restart but the screen turns blank after shutting windows down. So I have to manually restart to get it back up. Comes back up and with half default bios settings as if something failed, clock shows at 2.13 (Right when I start the OC it does read 2.66 on Boot up) ... Go and put everything back on defaults and everything is fine... I don't see whats the problem looking for any advice.
Could it be the TME1, "Thermal Protection", maybe?
Thanks!
Setup...
E6400
GA-965P-DS3
eVGA 7900GT
333x8 (2.66 Ghz)
Vcore of 1.375
Dimm +.2v
Thanks!
