Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Htpc + decent work machine - is it possible?
Forum Graphic & Displays : TV/Video Cards - Htpc + decent work machine - is it possible?
Hi,
I'm trying to put together a machine that could possibly double as a htpc (i.e. very silent) and a decent working machine. My budget is sort of limited, even though I can be convinced to break it if a significant upgrade can be made for only a small amount of money. I dont OC and I do not expect to be doing much gaming (at least not hardcore 3D stuff - mostly strategy). Here's what Ive got so far:
core 2 duo 6300 (183 $)
zalmanCNPS9500 cpu cooler ( 49$)
seagate baracuda 7200.10 SATA2 320 GB (read that these are silent 95$)
some DL dvd burner (~30 $)
hauppage 350 (150 $ need european PAL-version)
total expense so far: 500$
My budget would be around 650-700 $.
I need help choosing a stable motherboard that contains the following features:
SATA2 raid (could come in handy),
2-3 PCI (1 for the tvtuner, later option for a digital OTA tuner , WIFI)
1 ePCI (for a videocard see further down)
sound with digital out (coax or otherwise)
passively cooled northbridge
and I need advice on memory as well, how much is it worth paying? And which brand is reliable? 1gb should do it.
I would like to have a decent graphics card and it should be nvidea chipset as these are better suported under linux (I intend to run mythTV). It should have s-video-out (maybe even hdtv-out) and should be passively cooled.
I already have a powersupply, so I dont need a new one.
Im aware that this is overkill for a htpc, but I potentially need to do some work (numerical simulations) too so I want perfomance without getting too much heat and want a clear upgrade path.
Any comments and thoughts are appreciated.
Sponsored Links
Dump the zalman. Expensive and not the best performer on the noise front. For a quiet PC:
- Scythe cooler: the Ninja works passively and is probably the first choice
- Samsung spinpoint hard drives
- Seasonic S12 PSU
- low cfm 120mm case fan
Reply to mcgruff
just curious whats a htpc i been seeing that saying all over the place recently.
Reply to EnFoRceR22
Home Theater PC I believe..........
Thanks for the help so far - still need help on a motherboard and memory - should I put that question on another thread?
Reply to htpc-fan
There are 1165 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
