Using CoreTemp and Everest my temps are 41 C at idle and jump to 63 C at full load (5 or 10 minutes of dual instances of Prime95).
I've tried re-seating the HSF... removed HSF (stock) and cleaned off the stock Thermal Paste with alcohol added AS5 in a line per the AS websight and re-seated the fan.
CPU is running at stock speeds and voltage.
I know these temps are high - is a 20 C delta between idle and load normal?
Is it just me or do there seem to be a lot more instances of C2Ds running hot on this board than others?
Has anyone not been able to fix temp issues by re-seating the HSF?
SPECS
e6400 at stock speeds
Gigabyte p965-DS3
GeForce 6800
system hdd 74 GB raptor
storage hdd 160 Maxtor
case = Lien Li 7b pluss 2 (2 120 mm fans one in front one in back + 80mm blow hole fan.
Antec TruePower 550W
1 GB (2x512) Nanya RAM @ 533Mhz
SPECS
Gigabyte p965-DS3
GeForce 6800
